Fan Speed, New Version 0.92.6
edited November 2015 in Questions & Answers
"Set fan speed at move defined, not earlier"
I do not understand this work.
You can get information???
thanks
sistem Delta printer
  • If you send 5 move commands a fan on and 5 more move commands the firmware would normally buffer the first 5 and start fan also it is not at that point of print. Now it will enable fan after the first 5 moves where it was planned. This is more interesting if you have a slicer that changes fan speed for different parts so the right parts get right cooling.
  • edited November 2015
    during the first printing after the G28 the fan is switched on until the top of the layer of
    turn off immediately.
    if I try to manually extrude the fan starts work
    excuse my inglish use traslator google
    :-S
  • Sorry, but I could not understand the exact circumstances and if it is an error. I tried a print etc. and all went as I expected it. It all depends on the gcode and what fan commands you get. Can you sketch a short command sequence where the error happens and say at which point is gets wrong?
