Webcam
I recently installed a webcam and it is working fine on the host pc. When connecting with another machine, on the local network it works, but if I connect from outside my network it doesn't. I can print and all that so my connection is good, but no webcam image.
Any pointers.
  • That is because you have entered the local ip address of the webcam. That is why it only works inside your local network. If you also route it to external ip and enter external ip you can see it everywhere. We are thinking about a solution that detects the source, and allows setting a internal and external ip. But until then it will only work with external ip.
  • Thanks!
