Problem with heating during print.
Hello there,
i just installed firmware 0.92 on my Davinci 1.0. Everthing works great except printing. When i load filament, it works great. Once i start to print one of the sample files in the firmware it looks like the extruder is not heating because no filament is coming out but the motor for the filament tries to push. Maybe theres something missing in the settings?
  • Maybe just check if it heating or heats on heating command. After all it reports temperatures so you should know if it does. Also check the log and make sure you have not dry run selected, which prevents heating anyway but can also be enabled by an error. Therefore always read the log when searching for errors and solutions.
