Error:Z-probe failed
Hello, I think there's a problem when Z-probe is defined on same pin than min Z end-stop.
I have Z-probe failed error from time to time when nozzle hit bed without any clue on what happened and I can't achieve Bed Height map creation. The Z motors wires are far from endstop wires, I doubt it can be caused by EMF.
Hardware used : RAMPS 1.4 on Mega2560, cartesian printer, optical endstop with electronic pullup (10k to Vcc), pullup diabled on both Z-probe and end stop in Configuration.h.
Firmware : 0.92.3
I guess the endstop code occur just before Z-probe one and conduct to a missed step so stepsRemainingAtZHit remains negative. Perhaps endstop detection could be disabled when unsing Z-probe commands.
Feel free to ask me any other details.
Regards,
Nicolas.
  • I am having a similar Z-Stop issue with firmware 0.92.4 and 0.92.5. Delta Configuration. Mechanical normally closed z-probe on effector. Verified working with ohm meter. Bed leveling works with RC Marlin.
    The issue is my Z-Probe always reports back High with an M119. Doesn't matter which pin location I move the endstop too, even unplugged.
    Here are some configuration settings that I think may be relevant:
    Enable Z-Correction: Yes
    Store Correction Data in eeprom: Yes
    Always Check Endstops: Yes (confident in no cross talk)
    X Min Endstop: Not Installed, Pin: Disabled
    Y Min Endstop: Not Installed, Pin: Disabled
    Z Min Endstop: Not Installed, Pin: Disabled
    X Max Endstop: Yes, Pin: X Max Endstop
    Y Max Endstop: Yes, Pin: Y Max Endstop
    Z Max Endstop: Yes, Pin: Z Max Endstop
    Enable Z-Probing: Yes
    Enable Automatic Bed Leveling: Yes
    Enable Pullup Resistor for probe pin: Not checked
    Z Probe Pin: Z min endstop
    I kind of think it's a bug, since everything works in Marlin and it all Ohms out working. M119 is useful, but never sees a low state Z-Probe, no matter what.
  • edited October 2015
    I figured it out.
    in Configuration.h #define Z_PROBE_PULLUP is set to 0 by default, which is disabled. I switched it to 1 and my state now toggles correctly with M119.
    This is tied to the "Enable pullup resistor for probe pin (Z_PROBE_PULLUP)", which needs to be checked.
