Reptier Host on Raspberry Pi 2 without screen
i've installed the Repetier Host on a Raspberry Pi 2 with Debian Linux. I use the Raspberry only via TightVNC and without a Screen.
At starting the Host there is no Splash Screen, but the CPU is working... then i see a task of Reptier Host short - then it closes.
Here is the console text:
pi@3Dprinter ~/Downloads/RepetierHost $
Could not set X locale modifiers
Xlib:  extension "RANDR" missing on display ":1".
(mono:2753): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-can-change-accels after class was initialised
(mono:2753): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-menu-popup-delay after class was initialised
(mono:2753): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-menu-popdown-delay after class was initialised
OpenTK.Graphics.GraphicsModeException: Requested GraphicsMode not available.
  at OpenTK.Platform.X11.X11GraphicsMode.SelectGraphicsMode (ColorFormat color, Int32 depth, Int32 stencil, Int32 samples, ColorFormat accum, Int32 buffers, Boolean stereo) [0x00000] in <filename unknown>:0
  at OpenTK.Graphics.GraphicsMode.LazySelectGraphicsMode () [0x00000] in <filename unknown>:0
  at OpenTK.Graphics.GraphicsMode.get_Index () [0x00000] in <filename unknown>:0
  at OpenTK.X11GLControl..ctor (OpenTK.Graphics.GraphicsMode mode, System.Windows.Forms.Control control) [0x00000] in <filename unknown>:0
  at OpenTK.GLControlFactory.CreateGLControl (OpenTK.Graphics.GraphicsMode mode, System.Windows.Forms.Control control) [0x00000] in <filename unknown>:0
  at OpenTK.GLControl.OnHandleCreated (System.EventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WmCreate (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.UserControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Unhandled Exception:
System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
  at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in <filename unknown>:0
  at System.Drawing.Graphics.GdipMeasureString (IntPtr graphics, System.String text, System.Drawing.Font font, System.Drawing.RectangleF& layoutRect, IntPtr stringFormat) [0x00000] in <filename unknown>:0
  at System.Drawing.Graphics.MeasureString (System.String text, System.Drawing.Font font, Int32 width, System.Drawing.StringFormat format) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:MeasureString (string,System.Drawing.Font,int,System.Drawing.StringFormat)
  at System.Windows.Forms.TextRenderer.MeasureTextInternal (IDeviceContext dc, System.String text, System.Drawing.Font font, Size proposedSize, TextFormatFlags flags, Boolean useMeasureString) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.TextRenderer.MeasureText (System.String text, System.Drawing.Font font, Size proposedSize, TextFormatFlags flags) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.OnParentChanged (System.Windows.Forms.ToolStrip oldParent, System.Windows.Forms.ToolStrip newParent) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.set_Parent (System.Windows.Forms.ToolStrip value) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.ToolStripItem:set_Parent (System.Windows.Forms.ToolStrip)
  at System.Windows.Forms.ToolStripItemCollection.Remove (System.Windows.Forms.ToolStripItem value) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripDropDownItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripMenuItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.ComponentModel.Component.Finalize () [0x00000] in <filename unknown>:0
Requires this software forcibly a screen?
Thank you
  • Sure it does. It is our gui software. For headless service or a printer please use Repetier-Server which is meant to run from a Raspberry Pi and controlled via browser or Repetier-Host on a real PC with screen.
  • Okay thank you, for your reply!
