error in print preview
Hello everyone, sorry but I'm new to this. I installed yesterday repetier slic3r host and use, but when trying to visualize the result of elic3r I get the following error and shows nothing.
22:56:26.592 : OpenGL error:InvalidValue
22:56:26.592 : drawmoves: 3d visualization disabled due to OpenGL error
22:56:26.592 : Out of video memory - disabling filament visualization
Can anyone help ?, thanks best regards
  • Is this in 1.5.6? 1.0.6 was very strict and made every error a out of memory error so you didn't see anything. Should be more relaxed now.
    What does th elog say about OpenGL driver and what os and graphic card are you using?
  • 00:17:24.703 : OpenGL version:1.5.0 - Build 7.14.10.4935
    00:17:24.703 : OpenGL extensions:GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_ARB_texture_rectangle GL_EXT_texture_rectangle GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_lod_bias GL_EXT_texture_filter_anisotropic GL_EXT_texture3D GL_3DFX_texture_compression_FXT1 GL_IBM_texture_mirrored_repeat GL_NV_blend_square GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_WIN_swap_hint
    00:17:24.703 : OpenGL renderer:Intel 965/963 Graphics Media Accelerator
    00:17:24.703 : Using fast VBOs for rendering is possible
    00:18:10.312 : Analizando objeto...
    00:18:10.312 : El objeto no esta cerrado.
    00:18:10.328 : Analisis finalizado.
    00:23:40.062 : Slic3r command:C:\Documents and Settings\Mjldc\Escritorio\REPRAP\Slic3r\slic3r-mswin-x86-1-2-9a-stable\Slic3r\slic3r.exe --load "slic3r_settings.ini" --print-center 100.00,100.00 -o "composition.gcode" "composition.amf"
    00:23:41.312 : <Slic3r> => Processing triangulated mesh
    00:23:41.328 : <Slic3r> => Generating perimeters
    00:23:41.875 : <Slic3r> => Preparing infill
    00:23:41.968 : <Slic3r> => Infilling layers
    00:23:43.187 : <Slic3r> => Generating skirt
    00:23:43.187 : <Slic3r> => Exporting G-code to composition.gcode
    00:23:43.921 : <Slic3r> Done. Process took 0 minutes and 2.625 seconds
    00:23:43.921 : <Slic3r> Filament required: 559.0mm (4.0cm3)
    00:23:46.000 : drawsegment:UpdateVBO failed - disabling 3d visualization
    00:23:46.000 : Out of video memory - disabling filament visualization
  • Hello !, Thanks for your answer, I'm using version 1.5.6. All
    is well until I make the slicer of the
    piece. After that I get this error message and will
    not let me print. In manual control, I can handle
    100% all functions
    of my Prussian i2. I'm using Core 2 Duo T5670
    1.8GHz 3GB of
    RAM (HP550). Also
    use XP SP3.
    Repetier says as
    you are printing (up indicating progress percentage
    and print) but
    nothing moves in the printer .. I copied down
    some of the fault lines, I'm grateful for any hint, Best regards
  • Can you put a small gcode where that happens on dropbox or similar so we can have it for testing?
    Seems like our graphic drivers are more tolerant if it is an error since we see it every time.
    You haven't shown any lines from your print which does not print, so can not say why that did not work. It should be independent of visual display.
  • oK, Thanks you y add STL and GCode in dropbox
    https://www.dropbox.com/sh/btz752uw7j8ebzq/AAAkbCGg3nZN_AwF47l2y0-Ta?dl=0
    It is very
    rare
    , I am again
    trying to use Repetier Host. If you can see the gcode
    or stl can
    identify my error. I can not see the object filleting after using slic3r
    (I see just before
    filleting 3D). and
    when I print
    if I am guided by the screen Repetier it
    seems to be printing, but look at
    the printer and is not moving. remember that in manual control the
    printer control it 100% without any kind of problem. Thanks once again
    the error is:
    21:58:55.750 : drawsegment:UpdateVBO failed - disabling 3d visualization
    21:58:55.750 : Out of video memory - disabling filament visualization
    immediately after filleting with slic3r
