Repetier-Host V1.5.6 in Windowa 10.
Just installed the latest version on a Windows 10 PC.
the Program just keeps stopping, at various times. No set point in the printout.
Very annoying now back to using the SD card again,
Is there an area where you can see a log of what is going on or can I send you the log to fix the error.
Only happening with this latest download and this program.
  • What doe sthe log say about opengl? If it selected the generic windows opengl it will not be stable. It needs a hardware accelerated OpenGL version. Eventually selecting a different OpenTK version in 1.5.6 installer will help (legacy or not legacy)
  • It seems everyone that problem gets the generic gdi OpenGL driver selected through OpenTK.
    Try changing your anti-aliasing setting in host->preferences->3d visualization or installing the other 3d graphic driver. 1.5.6 has a checkbox during install to use the newest or legacy version. Once the log does not show renderer: Generic GDI the crashes should stop.
    Latest download made new OpenTK version default, in 1.5.5 you had OpenTK 1.0 which is now the legacy 3d library you can select during install.
